Convert JPG files to grayscale format
HONG KONGer
I have some files taken by digital camera which saved in 24 bit jpg format. I want to convert them to grayscale to save as much space as possible without lossing detail.
As I know jpg files are 24 bits and gif are 8 bits only. So should I convert them to grayscale gif format? And how do I do it in photoshop?
Go in photoshop and turn down the color saturation all the way. It is under the image adjustments menu.
which format should I save in to save more space?
And how do I convert all file at once?
jpg is a pretty good quality to size compression format. Just try some different settings and see what looks best to you.
