i just read that converting a 9800pro to a 9800xt enables overdrive,plus temp reading.anyone know if this is true or not for a msi 9800pro with r360 core?
you can flash it to an XT if you have the r360core that can handle the XT's speeds, but you wont get overdrive temp readings unless you have the actual XT circuitboard too, which most 9800pro's do not as far as i know
