Derfnofred
- Dec 11, 2009
Little bit of modest gaming, office, photoshop, occasionally COMSOL which loves memory/bandwidth more than anything else
If we can cap this at $500, I'd be thrilled.
Portland, Oregon
Looking at motherboard/processor/memory for the moment, and then I can worry about incremental improvements past that. (There are plenty to be made!) A low-cost HDD would probably be good since my platter drive is also 8 years old.
Antec Mini-P180 (micro ATX)
Earthwatts 650 PSU
Sapphire Dual-X 280x
Samsung 840 EVO 120 gb OS drive
WD Black 1TB (from 2010!)
Gigabyte GC-WB867D-I Wi-Fi/Bluetooth
Some LG SATA DVD drive
Hyper 212 Cooler (adapters to fit new sockets?)
PS2 keyboard, usb mouse
Used market is a possibility, in which case I have 2x4gb GSkill 1333 DDR3 sticks in here.
6) Will you be overclocking?
Modest, if any needed.
24" 1900x1200 monitor for now.
ASAP, computer seems to be starting to misbehave, freezing up and having a difficult time POSTing.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
micro-ATX is a must.
eSATA, audio, WiFi would be a bonus (card above could go in another computer), FW would be nice, will probably stick with SATA for internal drives.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Win7 Pro unlocked licence that I already rolled over to W10, not sure if that part is transferable?
My guess is either the memory or the motherboard is dying (cpu does fine under stress tests?) but system is occasionally doing the following: freezing, throwing errors on DX11 shaders, and POST locking up. Probably time to give it a proper upgrade, not sure how well the used market is versus just moving up to use some of the black Friday sales. Biggest $ hit will assuredly be the DDR4.
Was thinking:
Newegg: 1600x, ASRock AB350M Pro4, and 16 GB DDR4 (whose?).
Don't know if you could get a 7600k competitive for the same money (more on the z270 side!).
Portland, Oregon
Earthwatts 650 PSU
Was thinking:
