Convection Case
papa_otter
Anyone tried this yet? Im thinking something like one of those old mac cubes. Custom made cube case with a 120mm in the bottom, vented at the top. Will this be enough to keep a newer system cool?
The answer to your question depends mostly on the type of components you're using. If we're talking about a P4 Prescott (D), then pure convection wouldn't work, unless you were to use heatpipes and enormous heatsinks (see Zalman's offerings, for example).
Remember that the Mac Cube was akin to a P2/low-clocked P3 in terms of heat output, and it still overheated.
You mentioned using a fan, so I assume you're not going for a 100% passive solution (like the Mac Cube)?
Thanks for the replies. Yes, Im thinking of using 1 or 2 120mm fans mounted in the bottom. The whole top vented. Most likely Ill go with an amd midrange processor with a x800xl. I would like to make a custom wood cube built around 2 cheap metal case frames. So I guess no not really convection but looking to get low powered fans to replace everything.
edit:thanks for the link
In my opinion the best aircooling solution is used for the PowerMac G5, with thermal zones ('ducts') and a lot of thermally controlled fans. It's quite silent, even with a power-hungry beast (beasts) of a CPU.
If you decide you want to use a less forcefully forced convection configuration, then I'd advice you spend some time working out the thermo- and aerodynamic aspects of it, as it's not as easy as it may look at first. Alternatively you can build multiple test configurations, and test the airflow and temperatures..
