I have a Vantec Stealth 120 and would like to control it's fan speed (I believe you can go anywhere from 5-12V). Is there a way to do this other than buying a FanMate2 or some sort of fan controller other than manually rewiring the connection?
How do I do it? I'm considering buying some Yate Loons but would like to run them at 7V instead of 12 to be quieter. Would I do something similar to those to control the fan speed?
Thanks!
Thanks!
