Controlling FAN speeds using speedfan?
Noni
Hi guys,
I recently bought a Zalman 92mm case fan for my comp. Presuming its zalman I thought it would be quiet. My god how I was wrong!
Its REALLY REALLY loud. I thought speedfan would help (I have a ASUS A8N SLI DELUXE and the fan is connected VIA 3 PIN to my mobo).
What exactly do I do in speefan? I tried to go to configure and select "Logged" on the fan. Then I put it to 50%. Nothing changed.
Thanks for any help!
You can\'t control fan speeds with speedfan. It\'s made to monitor them. The only fan controllable by default is the one connected to the mobo 3-pin header (usually the HSF).
