Controlling 4-pin CPU fans?
scottmso
I did an upgrade to my system a few months ago: Pentium D 915 retail with 4-pin CPU fan and (cheapie) ECS P4M800PRO-M motherboard with a matching 4-pin CPU fan connector. I read that the extra pin on the 4-pin CPU fan connectors is for PWM fan control. I looked in the BIOS for any ways to control the fan but I only saw one, which seemingly set it to run on low speed all the time. Are there any programs that I can use to manually control the fan? Any advice appreciated - thanks
what you need is a decent cpu cooler that will run quiet ALL the time. :p
speedfan will allow you to control the speed of any fan that is connected to a motherboard fan header
I would buy a new HSF but I'm a little short on $ and I've had a hard time finding something that is inexpensive, quiet enough, and small enough (my case is tiny - Ultra MicroFly.) But I'll try SpeedFan - thanks!
