that lsi hba is pci-e 3.0 x8.
let me put it in another way:
i have 4 pci-e 2.0 x1 and 2 pci slots free. What would you use?
with that lsi hba. Pcie x1 and pci have way to low bw to run ANY hdds (maybe 2) let alone 40.In all honesty, I would add a new motherboard into the upgrade budget.
In all honesty, I would add a new motherboard into the upgrade budget. In any case, how many users will this 40 drive array see, what kind of data will you be storing on it predominately and how will the users be accessing it? How many arrays do you see breaking these 40 drives into? Are you planning on Hardware RAID? What level(s) are you planning? What are you planning to use to backup the ~80TB (before parity loss)?
the hba suggested seems overkill.
