Sep 11, 2004 #1 S Syrnix Limp Gawd Joined Oct 27, 2003 Messages 213 Is it the controller card or the OS that determines whether you can have more the 137gb on a hard drive.
Sep 11, 2004 #2 D defakto 2[H]4U Joined Jun 10, 2004 Messages 2,323 the controller card usually, as it needs to support 48 bit LBA, but there may be something in the os also, i could be wrong on that though.
Sep 11, 2004 #3 P psi.monk Limp Gawd Joined Aug 12, 2004 Messages 160 The short answer is "Both" but you should really reead this: http://www.hardforum.com/showthread.php?p=1026129864#post1026129864
