I bought 3 silverstone FM121 fans(and 2 FM92 fans), they come with their own fan controllers that connect with 2 wires(+ and -, no rpm wire), it has a seperate 3 pin connector(actually only 1 pin, just yellow that sends rpm info to the motherboard/fan controller). I bought a fan controller(sunbeam windmill) that is supposed to control the speed of the fan based on case temp, it connects with 3 pin connections though.
If I connect the 3 pin to the fan controller and the 4 pin power molex, it reads the rpm's just fine, but the fan only spins at 100%. If I also connect the 2 pin controller that came with the fans, I can adjust the rpm's.. What I'm looking for is an adapter that I dont think is even made..
The adapter i need has on 1 end that connects to the fan: 3 pin male connector that has the yellow wire, 2 pin female connector that has red/black, and the other end has 3 pin female connector with the yellow/red/black..
Does anyone know if something like this even exists or how I can do this? Silverstone fans seem to be pretty popular, I wouldnt imagine something like this would be so hard to find..
