control key
Incinerator
hey Im not sure what happened but whenever I use my control key my computer beeps (as if I were hitting two keys at once) and sometimes it highlights everything on the page. Anyone know whats goin on here?
Thanks
This sounds like some sort of accessibility feature is enabled(perhaps stickykeys or something). If you are using windows, open the accessibility control panel and turn off everything you don't need.
Start>Control Panel>Accessibility Options (it's the top one).
And like he said, uncheck everything you don't need.
