How dark black can go affects how darker colours look. The darker the better as it makes colours look richer.
(think of it the other way round, the brighter black is, the more colours look washed out, then reverse it)
It also affects your perception of darkest black.
How bright white can go affects how brighter colours look and affects your perception of white.
Fitting a brighter light behind the same LCD panel wont increase the contrast ratio because it will increase black and white by a similar ratio.
Better contrast ratio displays are mostly defined by how dark they go.
Although Sony recently demoed a new type of lighting system that adds extra light for very bright scenes, this also increases the contrast ratio without affecting black levels, but this type of boosting is rare.
Hey, mate.
I understand all of that stuff. Maybe that's all there is to know?
But, I assumed the contrast ratio also affected colors. Does it? Is it significant (does it have much impact on the perception of image quality)?
I ask, because I hear people saying that the Samsung 4k has poor contrast.
Thanks for taking the time!
Fitting a brighter light behind the same LCD panel wont increase the contrast ratio because it will increase black and white by a similar ratio..
It's worth pointing out here that this only applies to TN and IPS panels. Modern VA screens regularly achieve in excess of a 3000:1 ratio in independent testing.Realistic contrast ratios for LCD monitors range between something like 800:1 to 1200:1, maybe a little more these days, but getting over 1200:1 on an LCD is hard.
