Carbon_Rod
- Apr 2, 2012
I've been planning it for awhile now.... it's the perfect project to keep me occupied over the next couple months. But I have questions... I'm hoping you 4P mafia members can help me with some answers.
1) For those of you with 4Ps, what kind of power draw are you seeing while folding? You see, another one of my dilemmas is that I actually thought I would start by building a 2P system, so I started by buying a PSU based on a 2P requirement. So I now have a brand new AX850 sitting here, but will it be enough to power a 4P? even with a moderate OC? I think I still may start with 2 CPUs and then add later, so even if I had to upgrade the PSU after adding 2 more CPUs, I could still use it initially.
2) I'm looking at the Supermicro H8QGi+-F, but have also looked at the SM H8QGi-F... I see that the H8QGi+-F only requires 2 additional EPS12V connectors whereas the H8QGi-F requires 3. Hopefully someone will be able to answer this, but is this because the H8QGi-F has the additional PCIe slots and the extra EPS12V is required for powering them? The only reason I ask is that I haven't found any mainstream PSUs that have 3 EPS12V connectors in the event that I have to, for some reason, settle on the H8QGi-F over the H8QGi+-F. I know there's always options for adding a 3rd EPS12V through an adapter of some sort, but I was curious if it was even really required on that board.
Any information provided is greatly appreciated... thanks.
