Don't buy these routers for their Wireless capabilities. They are really bad routers and CISCO refuse to fix.
These routers have a faulty drivers for their wireless network cards, CISCO knows this but they will not address the issue. Infact these routers might actually have a hardware problem as well which means that the firmware will not fix the problems. I guess they need a lawsuit just like dlink got to get their act together.
Symptoms.
You wireless connection will drop every hour so.
Spotty connections, it will hover any where from 1mb to 54mb.
Router will completly freeze up every 24-36 hours of uptime. You will need to reboot the router at that point.
If you try to transfer any file over 60mb you will cause your router to completly freeze up or it will reset you connection.
These problems seem to effect the following hardware Revisions: 1.1/2/2.2/3
Fixes
Return the router get another router that is not manufactured by the worst company on earth.
There is a Firmware which is beta (4.XX) that fixes some of the problems but there are still numerous problems. Call Linksys for it or google it, I found a link on sveasofts forums. After you get this firmare Turn your MTU down to 1474-1492 range and change you wirless watchdog from 100 to 50.
Any open firmwares that are based on on 3.XX official firmware will not fix these issues.
Misc Notes
If you're using the router for the wired capabilities you will not experience these problems, unless you choose to use the wireless.
Symptoms.
Fixes
Misc Notes
