Constint BSOD's and IRQL Problomes
scotepi
have posted this problem in another forum but no one there seme's to know what's wrong
http://psforums.station.sony.com/ps...scending&page=1
I have reinstalled windows many times, including going back and forth between windows 2k and windows XP pro. I also have a 9200se that my computer works fine with.
has anyone experienced a similar problem or have any idea as to what is causing this?
specs:
DFI Lanparty NFII revB
XP 2800+ Barton
2GB RAM PC 2700 cl2.5
IDE WD 80GB 8mb, WD 160GB 2mb
SATA WD 200GB 8mb , WD 250GB 8mb, WD Raptor 74GB 8mb
8x Plextor DVD+/-RW
48x24x48x16 LiteOn Combo
ATI Radeon 9600xt 128MB
some farther research It looks like a possible cause could be my TV card witch is at IRQL 10.
http://www.experts-exchange.com/Operating_Systems/WinXP/Q_20936254.html said:
When you get the stop error it will be accompanied by some information i.e.
Stop: 0x0000000A (parameter1, parameter2, parameter3, parameter4) IRQL_NOT_LESS_OR_EQUAL*** Address x has base at x - filename
The parameters refer to the specific issues that are involved:
Parameter 1 - An address that was referenced improperly
Parameter 2 - An IRQL that was required to access the memory
Parameter 3 - The type of access, where 0 is a read operation and 1 is a write operation
Parameter 4 - The address of the instruction that referenced memory in parameter 1
Make a note of the stop error ESPECIALLY the "filename" as this can point you to a defective driver or the software/hardware at the root of the problem. do a Google search on the "filename" To help you narrow it down.
