ThePerformer
- Jun 9, 2003
This is getting rediculous. I have been getting strange errors with my system for MONTHS now. I've solved all of them except one: the constant RAID errors which already cost me 500GB of data that I'll never see again.
When the other strange errors started, they were accompanies by RAID errors on my RAID 5 array of 4 Seagate 500GB drives. Several times a week, one of the drives would get an error on it, I would have to restart my computer and rebuild the drive. The exact drive which would fail was random. It was not a single drive failing. So then I reinstalled Vista. Still constant failures. Then I replace the motherboard and CPU and reinstall Vista. Still constant failures. I change the array to RAID 0+1 thinking that maybe the RAID 5 is just crappy. Still errors. THEN, I replace the RAM which finally seemed to calm it down. The other odd errors are gone and the hard drives were stable for two weeks straight.
In the last 5 days, I have had two different drives in the RAID 0+1 array fail (thankfully not at the same time), and just now, a drive in my RAID 1 system array (WD Raptors) failed as well! It's rebuilding right now.
WTF!!?!? This can't be hardware since it's all been replaced and this can't be software since it's all been reinstalled. It can't possibly be that I have 4+ bad drives.....HDs rarely fail as it is anyways and these are some pretty sweet drives.
So what the heck!?!? What could this possibly be?? I have a Lian Li case that is supposed to have massive cooling capabilities and the drives are not even warm to the touch. They even all use different cabling!!
I really need everyone's help. I HAVE to figure out what's going on because otherwise this extremely expensive system is basically useless. I've already replaced everything that could cause errors. Please help me guys. Thank you!
PS: MB BIOS is already up to date, nothing specific sets it off. Will add more thoughts as I get them.
