I'm in the process of overclocking my new Sandy Bridge setup, and I'm finding temps are a little high for my tastes. Max with Prime 95 and Intel Burn Test ranges from 68 C on C0 to 77 C on C2 (temps by Real Temp). Idle is between 33 and 41 C across the board. I'm only running at 4.5 GHz and 1.31 V (was getting BSOD after 45 mins with 1.29 V), which seem like pretty conservative settings. Do these OC settings seem normal?
As it says in the sig, I'm using a CM V8 and Coolermaster HAF X, so I thought my cooling should be pretty decent. I'm using ZEROTherm paste, but it's about a year old (though capped the entire time). Should I look at a new cooler, like the Noctua NH-D14? I like the insane cooling it provides, but I hate the low clearance for RAM sticks. I thought about a Corsair closed water solution, but they're apparently pretty noisy.
