Okay, first up I'm a noob at water cooling, so feel free to point out any blatently obvious things that I may have overlooked
Well, I've got a Vapochill XEII (so I don't need CPU cooling). I'm running a 6800U at the moment, but I'm planning to upgrade to dual 6800GTs in the relatively near future.
I was hoping to water-cool the SLI setup, but there isn't really too much room inside the vapochill case, and more to the point, the case supports only 3*50mm(!) case fan vents. Obviously if I've got 2 high end video cards pumping out heat into the case (whether via air cooling or water) it's going to get pretty hot in there, when the only means of ultimate heat escape is these three puny fans.
So - I'm looking into a watercooling setup external to my case. I was thinking about setting up a radiator on the top of my case, although I'm quite open to having a 'stand-up' system stood beside it also. I haven't planned exactly how I will construct a support or housing for the radiator or pump yet, but I will do that once I have bought them.
I'd want the setup to be reasonably quiet, although there is no requirement to be silent. My last PC had 5*80mm fans rated at ~34dBA, (as well as a 7-volted 92mm tornado). I'd *definitely* want it to be quieter than this, but there is no requirement for it to be 'silent'.
I was thinking of something along the lines of:
* Thermochill 120.3 radiator (probably mounted with the fans vertical)
* 2*NV68 water blocks for the GPU (although I'd consider the maze4 block instead, if it was likely that the nv68 wouldn't fit the next generation of video cards)
* a decent pump. Haven't really looked specifically into these at all yet...
* 3*vantec stealth 120mm fans.
Does anyone have any suggestions / comments?
I'm wondering how the 120.3 holds up against the black ice extreme III, and also if there are any other realistic options for radiators, given that I will be having them external to the case.
Also, how much of a performance increase would I see from going for fans that have a larger airflow? I'd like to use 38mm fans rather than 25mm like the zalmans, but it seems to be difficult to find fans that are 38mm but aren't designed to be very noisy.
Any other comments, or helpful tips for this noob?
I was thinking of using 1/2" tubing also.
Thanks for reading
edit - could someone also explain to me the benefit of having a resevoir? Other than the small passive heat loss that it will provide, I don't understand the benefits!
Thanks for reading
