Corban227
- Dec 2, 2009
Hey guys ive read the common questions forum but i still had a couple of questions (parts wise) and some maintenance questions..
to start, my case is the NZXT Tempest Evo:
Case
Interior
Web site information
The case has some nice water cooling features build in which intrigued me to look into it. specs are in my sig but to make somethings simpler i have a i5-750 and a hd5870 which i will be putting into the loop.
Budget:
Im trying to keep the budget cheap. don't want to go overboard. probably 200-300 max
Parts:
1. i have no idea what to even begin looking which is why im posting here first. i figure i have the option of getting a 140mm rad or one that goes over 2 140mm slots (not sure what that size would be..280?). the best place for this would be at the top of hte case considering there are holes pre-drilled for a rad.
2. the pump im amusing would go at the bottom of hte case next to the psu
3. im not sure where the res would go.. outside the case? suggestions appreciated.
4. The QA thread above recommends using distiled water, but i noticed that a lot of people who post use coolant or antifreeze. does it really work better than water?
5.also what parts should i get, and what brands should i be looking for? because i know nothing, i'm open to any suggestions. i have 0 preference
6. What would good 140mm fans be to purchase. the NZXT fans are fine for normal use but not for WC. Also id prefer to keep the system as quiet as possible.
(side note. owning an h50 kinda got me interested in water cooling. i don't really do any hard core over clocking but modding comps and building is a new hobby of mine. plus i love low temps lol)
Also i have a Lamptron FC5 fan controller.
Maintenance/Miscellaneous questions
1. How often do you have to flush the system? could i go 6 months without touching it once its set up or will it be a monthly task? im a college student in an apartment so major cpu maintenance is not an easy task.
2. if done properly how quickly do deposit buildups occur in the loop?
3. in getting a watter cooling system, is it recommended i keep all my fans?
4. also is it better to have fans puling the air through the rad or pushing if you had to pick one?
If any current pics are needed of my rig or location please let me know.
thanks in advance for the advice
Case
Interior
Budget:
Parts:
