dpoverlord
1+ Page OP OG Club
- Nov 18, 2004
I am in the works of building myself anothersystem,
The end result is that I will be giving him pretty much my current system as ponder the idea of switching to AM2. I was wary initially of making the switch due to the high price of DDR2 ram, the fact that AM3 will be out in around 6-9 months. I see that a 939 system is relatively cheap however it will have value down the line due to the fact that it will become obsolete.
With that being said, if I do stay 939 I would have to get a new ultra-D, new ram and a new proc. If I am going to be making this step it seems to make more sense to just go AM2.
I love the features and overclockability of the DFI-Ultra D, the fact that it has 2 IDE ports, and 2 Lan ports ( even though I really only use the Nvidia Lan port).
I have been doing lots of research on choosing the right AM2 board and was leaning DFI. I plan on going AMD just because I feel there prices will be cheaper and the chips seem to be very overclockable.
To my point, it seems DFI has many boards to choose from in the AM2 category. Considering the options I was looking for I was wondering what you would suggest and also on how my two preliminary choices are:
1. NFINITY NF ULTRAII-M2, I see this came out recently and have heard positive reviews, I am not 100% how it overclocks and I was never a big fan of the marvell Lan port but it should suffice.
2. LANPARTY UT NF590 SLI-M2R/G I have liked the Lan party line thus far, and was hoping this keeps up with the line. However it is significantly more than the UltraII-M2. I have heard the BIOS has and that the RAM Dividers do not work properly at certain FSB Speeds. Someone told me also taht the Voltages are reported wrong due to Typos.
My goal is to spend less than 500-600 on RAM, CPU and the motherboard I would rather spend 500 or less, Which means that my budget would be:
90-180 for mobo
200 for ram
200 for 2 GB of ram? 2x1gb??
Tell me what you think motherboard/system wise.
90-180 for mobo
200 for ram
