InvisiBill
- Jan 2, 2003
I've been in and out of this section, looking at things and reading up, but not in too much detail.
My rig
I've currently got my case full of YL D12SL-12's. They're fairly quiet and I'm happy with the cooling overall. Watercooling is about the only thing I haven't done with my PCs, so part of it is just wanting something else to play with. However, part of me doesn't want to have to worry about the extra issues that can come with water either.
I really like the radiator setup on this rig (I've already removed the plastic grilles from the front and top of my case). I'm just not sure how much a 120x2 can handle, and if other models fit as well as that Black Ice Pro II. If I will need to use that rad to get that fit, is its performance comparable to newer rads?
Could it handle an i7 and a GTX285? I may StepUp to the Classified, which gives me the toasty NF200, and I wouldn't mind it if I could crank the i7 up to 4GHz (though it's still great at stock speeds as well). What would you recommend for a stock i7 and GTX285? For an overclocked CPU, GPU, and the motherboard as well?
My rig
