considering mobo/cpu upgrade from 1366
Even though I am a fan of the x56xx chips for a quick easy upgrade, to be fair.
The x56xx is missing the new AVX instructions that are great for BOINC Primegrid and I believe FAH is using that instruction too.
I myself will upgrade after the next big new great release from Intel. I can't justify spending a thousand dollars for a whole new rig, the DDR4 prices are through the roof.
I will wait it out.
OP please let us know what you end up getting and how well ti works compaired to what you have.
comparing Haswell 22nm to x58 45nm chips man regarding heat/power consumption/performance
I'm gonna fall down laughing because this is too humorous rofl
lol
I'm not laughing with you
current rig:
i7 920 @ 3.6
ASUS P6T LGA 1366
G.SKILL Sniper Series 16GB DDR3 1600
GIGABYTE GV-R928XOC-3GD REV2 Radeon R9 280X
i've been wanting to upgrade mobo/cpu for a few years now but the good stuff is so pricy. i think i'm finally ready to drop a couple hundred bucks.
i'm on a pretty tight budget, no more than $300 total, preferrably much...much less :p
i'm looking at the ASRock Fatal1ty Z87 Killer http://www.newegg.com/Product/Product.aspx?Item=N82E16813157460 and maybe a 4690k to go with it.
i'm wondering if for that price there would be a better combo to go with, or even how much of a performance increase i'd see. i play alot of FFXIV and WoW-type games and i'm looking to pick up GTA5 in january. all at 1920x1080 with basically maxed settings.
i've found pretty decent deals on both of those here on [H] and ebay so i can get them both for around $300 total.
thoughts? :)
All of this debate seems to be missing the core question from the OP. For gaming at 1920x1080 in most games you probably won't see a huge difference with a CPU upgrade.
The 6-core Xeons are fun for sure, but they're not anywhere near as magical as the internet lore and mythology will lead you to believe. As many people have already mentioned, a 6-core Xeon at 3.6GHz is going to perform roughly the same as a 4-core i7-920 at 3.6GHz in just about everything you're going to use it for. You may be able to push it farther to 4.0GHz, but it's a marginal improvement. Be careful when reading the Overclock.net thread, because it's full of hand-picked benchmarks that glorify the 6-core Xeon.
On the other hand, if you do compiling, rendering, or other multi-threaded tasks frequently then the 6-core Xeon upgrade is basically a 50% performance boost and is an awesome bang for your buck. Gaming is not seriously multi-threaded though.
Jumping to Haswell will absolutely deliver some huge IPC improvements. But if you're not CPU bottlenecked, such as in most games, you'll not see much of a difference.
I'd recommend saving your money for another GPU upgrade in 6-12 months. Alternatively, current generation Haswell gear will likely be cheaper in 6-12 months. But unless you're struggling in any of the games you play right now, you're better off sitting on that cash until the next big upgrade comes out than spending it now on something you don't really need.
Or one other suggestion: 27" 2560x1600 monitor. But then you might find yourself wanting a second GPU as well. :D
I did HVAC-R for 33 years, Heating A/c refrigeration. I can say for sure that the 95W x6560 xpu is not like a vent from a hot air furnace
I have a H70 AIO water cooler and prime95 runs 62c to 65c or so, running BOINC WCG 100% load is 51c 12 threads. That is not all that bad. 4ghz at 1.28v
They really are a good deal at 60-85$ for an upgrade. They are as good as the 970x chips and are 32nm and 95w with 12mb of cache. They run cooler and use less power.
I doubt at 4ghz they will be a bottle neck in any game. But the OP made up his mind, maybe he will buy a x5650 for his kids system next year after he gives it to him.
Reading comprehension would have helped you a lot more than any amount of HVAC experience here. I never said it was the same as a hot air furnace. I was merely giving an analogy between how hot something runs and how much heat something produces, and pointing out that they are not the same thing.
Some more fails... OP did not state he wanted this upgrade to run BOINC. He wanted it for games. Games he listed. Games that would not benefit for 2 additional cores.
I just was saying what the x56xx was lacking. AVX instructions and what they were good for. Other people read this and may want to know what the differences are.
OP may run BOINC now, or he may want to in the future. And again I was trying to point out what was lacking in the x56xx chips.
To say something runs hotter but produces less heat when talking about CPUs is not like a lighter and a furnace vent.
Your lighter flame vs furnace vent not the best analogy, Not sure where you were going with it, it has noting to do with what we are talking about here.
Just seeing people saying more or less the x56xx CPUs are flame throwers. I disagree.
I posted real numbers of what the temps were with software most everyone uses. Instead of insulting me post some real temp numbers and prove your point.
No need to get personal.
The hexcore westmere/gulftown are not going to help you that much for most things..... vs an oced bloomfield....not really worth the upgrade..... unless you can score one for a good deal.....and your mobo has no issues running it / start modding BIOS etc....
still better to save and just update to Ivy or Haswell just the best bet no matter how you look at it...
this is the main reason i've gone so long without upgrading CPU. if i can get 50+ fps in current gen games on max settings, i'm happy.
this thread has given me alot of food for thought that needs digesting. i may end up just waiting it out for a while. i was looking at 290x prices yesterday and they are WAY below what they were when i last looked a few months ago. i just don't want my CPU to end up being a bottleneck.
hell i may drop $60ish on a cheap water cooling solution and try to push my OC. i've hit 4.1ghz with this cpu but the temps were outrageous.
I can only speak for myself but 5600 xeons are all i need until skylake at the very least. I love it when people post opinions about stuff they have never tried or used saying there not worth it. I don't remember seeing anyone who bought one with buyers remorse lol. And people saying it wont help for games, there again its almost always people who never used or tried them. When i rebuild it will be Haswell-E or more likely skylake.
A strong modern video card will always be the best upgrade for gaming.....if i spent any money today it would be an 290x or a nvidia 980 but even then i likely wait for 20nm cards. I cant help but think 99% of games are coded to be used on 8 core processors because of consoles so if not now at some point they will be, but who knows.
Again, you are still not understanding the difference between temp and heat, so posting temps from common programs is a waste of time if you don't understand the implications, which you aren't, since you seem to be using the terms interchangeably.
The amount of heat they produces is immense compared to Haswell, even if their temps are not.
yea but man i love the extra heat thru winter:D boinc or similar apps keeps my room at least 5 deg warmer when it comes to getting out of bed time...lol we use pcs to warm our house around here:D (sorry for being off topic lol)
just food for thought...but been at 4.2ghz on a VERY old single fan air cooler and never go above 70c much if ever. Think i have heard from most the 5660 and above models hit over 4ghz on very low voltage, which i guess makes the reason they run cooler, not to mention the smaller die fab compared to 45nm.
Maybe it was inexperience or idk but i never had luck getting my 920 to 4ghz....the xeon even with the extra core do it quite easily.
You could probably get this Intel Xeon X5660 http://www.ebay.com/itm/Intel-Xeon-X5660-Six-Core-2-80GHz-12M-Cache-6-4GT-s-LGA1366-CPU-Processor-SLBV6-/291300273251?pt=US_Server_CPUs_Processors&hash=item43d2d96c63 for 79 (with make offer) shipped and hit 4ghz at very low voltage and if you didn't like it you could resell it in the fs/ft forums for the same price.....my last one sold here in a grand total of 2 hours. sell your current cpu and your looking at somewhere between free and very low cost upgrade:D
Would you recommend upgrading to a x5660 from a 920 at higher resolutions than 1080?
At 1080 Im definately bottlenecking my 780ti at this point but at 3440x1440 my gpu opens up. Would I gain anything at this resolution with the Xeon. Was thinking about going with the new 5820k, but I just cant seem to get over the price for what I will be getting. But for $70 to $80 it seems worth it to get the 5660.
i sold my 920 for 25 bucks just to help out a forum member here, but i figure you could get twice that on ebay with very little fuss (they actually still pay around 150 in remote areas of the world).....that puts you at spending around 30 bucks tops for 4ghz and 2 extra cores.....how much it would help is uncertain especially at that res...but hell for 30 bucks, your not out much if it didn't help a lot. I think the answer really depends on where your currently clocked...if your already sitting at 4.2 cool and stable then it may not help as much as it did on mine. (but i was coming from 3.4ghz so the added clock speed alone helped):D
Hey, I hear ya. I fold during the winter.
I'm amazed at how relevant the 1366 socket still is. Those original i7's are still going strong and pack quiet a punch what..5-6 years after release?
I am trying to understand what you're telling me. But going to school to study temps and heat and how things boil and condense. I will explain how I understand heat.
Temp or temperature is just a measurement on a scale. The temp outside is 72f the temp water boils is 212 at sea level and freezes is 32f and so on.
There are three types of heat.
Sensible heat:.When an object is heated, its temperature rises as heat is added. The increase in heat is called sensible heat. Similarly, when heat is removed from an object
Latent heat:, Heat absorbed or radiated during a change of phase at constant temperature and pressure. 32f water and 32f ice remove the latent heat water turns to ice.
Superheat: To heat to an extreme degree or to a very high temperature.
to heat (a liquid) above its boiling point without the formation of bubbles of vapor.
Or to heat (a gas, as steam not in contact with water) to such a degree that its temperature may be lowered or its pressure increased without the conversion of any of the gas into liquid. Like high pressure steam in a steam pipe can be way hotter than 212f.
I know the more energy a device uses it gives off more heat. Electricity when turned into something we use it gives off heat. Turn it into a magnetic field as in a motor or a glowing resistive wire as a light bulb, it will produce heat.
Watts are the amount of energy used, more watts more heat'
BTU is another measurement of heat 100,000 BTU furnace 6,000BTU A/C unit.
So if a CPU uses more energy it will produce more heat.
Is that all you're trying to tell me?
Can you rephrase what you are saying so I can understand what you're trying to tell me?
By the way I am heating my house right now folding and crunching. Been folding 8 or 9 years now, time flies by.
I have three x5660 @ 4ghz12 threads, and1 dual processor x5650 24 threads and two hexcore 1045T AMD @ 3.4ghz 1 four processor 48 core AMD 6168, and 1 four processor 24 core AMD 8125 and a few GPUs that run off and on as I want to run them.
And one very large electric bill
I'm not sure how else I can rephrase it. You seem to be under the impression the difference in heat is minimal due to the temps you're seeing. I'm saying you can't compare temps between the two processors and say the amount of heat they give off is the same or similar because temp != heat. Which is exactly why I provided the flame from a lighter vs a heating vent analogy. One has higher temps, but the other has far more heat output. Or in other words, the object with the hotter temperature is actually giving off less heat.
But they are both 2 inch square cpus, the same size. If one had far more more heat, it would be a higher temperature, end of story. What you are saying is not possible.
The vent has more heat (BTUs) than the flame from a lighter. It is not as concentrated as the lighter flame. That is why the flame will burn, But it has less BTUs.
Go to the source of the vent, the furnace, there is a lot more flame than at the tip of the lighter. Hundreds times more flame than at the tip of a lighter.
Try putting a bic lighter in you furnace and see how hot the vent is. It would be cold, not concentrated Get 2 feet away from the lighter it will not be warm at all.
SO
It looks like we will have to agree to disagree and move on.
All the Xeons/Server chips are binned better/better Silicon simply they usually OC better/higher at lower Vcore and they will just handle heat better....
But yeah tempted to pick up a Westmere/gulftown to see if its really anything worthy rofl,
And yes I may have gotten upset in previous posts but you should not insult my intelligence/knowledge/Experience with all this....This isn't my first Rodeo bud haha
SO
You cant agree to disagree on something you clearly don't understand.
Die size for the xeon CPU is 240mm^2 die size for a 4770k is 177mm^2 and that's WITH an integrated GPU which takes up a huge chunk of that space. What that boils down to is the actual CPU portion of haswell being much MUCH smaller and more highly condensed.
I'm trying to be patient but you clearly have no idea what you're talking about. You think heat and temp is the same, and you think package size and die size are the same. If you disagree, you're wrong, it's really that simple. These are facts, not my opinion i'm preaching
If that wasn't enough evidence for you, we have TDP... 95 watts for Xeon in question vs 84 watts for Haswell. Again, that's WITH an integrated GPU as well as an integrated voltage regulator and even still, it's TDP is 11 watts lower.
Oh, but wait. We aren't done yet. The boards/chipsets for Haswell also consume less power, and thus, less heat.
And for some more reading comprehension fail, I said the heat coming out of a vent, not the flames that are in a furnace. This was quite clear since I mentioned it once, then explained it once, mentioned it a second time and now explaining it a second time. All but the first time was for your benefit. Where exactly are you getting confused?
For gods sake man, why didn't you just say that in the first place? You do not understand that temp is just a number on a scale, you are using the word the wrong way. Talking about vents and lighters was dumb, just say what you did right there.
And did you not see where I said if it uses less electric (watts) it will be cooler? Can't you read either? Good god man you are the worst communicator on Earth!!!!!!!!
Go learn about BTUs vs temp vs CFM and how all that works together.
It truly was the worst analogy ever. DO NOT go into teaching,
PS: or HVAC!!!!! lol
HAHAHA love ya brother folder. Now kiss my ass!!!!! :p
I didn't say that in the first place because this thread isn't comparing die sizes. I only had to mention it now to educate you because you decided to debate a topic you are unfamiliar with. I mean, I already knew you don't know what you were talking about, but when you mentioned both CPU's are 2" square, the extend of your ignorance was apparent.
The analogy was perfectly fine, you not getting it is just another on the long list of failures on your part in this thread.
No he is correct better more/smaller transistors/smaller die far more efficient/consumption/ less heat etc,
pretty simple really.
I kinda think I had the best idea in this thread, go for the x5650 or x5660 for cheep and put the saved money on a better GPU. There is no way he will bottleneck the X56xx cpu in any game. You have not proved otherwise.
People who call other people names in a discussion usually have nothing intelligent to say.
You are proof of that.
You think you are the smartest guy in the room, you're not. Get over your self.
Be a little less condescending and maybe someone will actually
like you.
Depends what hes doing....if a bunch very mult-threaded tasks/ oriented, then yeah extra cores/Hyperthreading works well with that.... but like gaming no...still very single threaded.....can be hard to get 4 cores really ramped/up working/usage in even most demanding titles.....
this is slowly changing though.... why still quads are plenty and hell look at the benching on even ivy/haswell dual cores etc..... at this point speed/single thread far more important/useful.
unless he can get a 5650 real cheap....to be honest $70 used off off ebay when I picked my Xeon w3520 up for $15..... and it OCs at better Vcore than pretty close batch actual 920....what the hell....Both DO chips too late batch though....swear op sounds like he has CO stepping chip and yeah them bastards did NOT want to do 4ghz at all.....even my w3520 is kinda crappy still takes 1.4v to be up there... its a little better not no where like early batch DO chips the alleged golden chips hitting 4ghz at 1.2-1.3vcore no fucking way really? kinda would be nice a lot less damn heat/stress on VRMs etc... still more stable/cooler than my 920....
why don't you ask all those amd quad core owners how much cpu usage there seeing in titles like bf4? And im not talking about mantle either....when that game launched it was pegging all 4 cores to 100% on there 4 core cpus and they for the most part couldn't even play the game....now older i7s with hyperthreading and only 4 cores did just fine...that kinda leaves me to believe that game was not single threaded in the least but actually used 8 threads instead. Not trying to argue in the least but pointing out that extra cores can come in handy in certain games.
like you.
I'm sure *you think* you have the best idea. But you also thought a whole lot of other things that were wrong. You didn't know the implications on the topic you decided to debate with me, which showcased your lack of knowledge in multiple areas, and you don't know the implications of the upgrade you're suggesting either.
And I didn't call you "names" I said you were ignorant, which is true. When you come back and say what I'm saying is "impossible" but reality dictates that not only is it very possible, but it's what is actually happening, that's ignorance.
actually BF4 runs like shit with HT on no matter what I try lag/hitching etc...not like you need it anyways... and for one you are talking about AMD....rofl its amd dude no comparison.....Bulldozer/Piledriver are really just shit kinda rofl 8350 can have/be very impressive with multi-threading tasks but single thread/core performance is still kinda shitty rofl,
Im gonna guess he was really talking about the size of the heat spreader which would be close to the same right?;)
you really are making a false statement saying bf4 runs terrible with ht on.....im going to make a wild guess here and say your under the age of 20? Im not trying to insult you but your facts are way off from being remotely true that im going to attribute it toward your age and not that your a retard or or anything:D and please don't end every post with rofl unless you really are retarded
To OP:
I really loved the 1366 / x58 platform. It was by far my longest lasting system. Built it the day the came out (how many years ago was THAT!!) and am finally retiring her.
Replacing my 1366 i7-990x next month. Had such a good run with the thing. The 6 cores handled video encoding pretty damn good and overlocked to 4.53 it handled any game I could throw at it (I was constantly upgrading video cards thorough out its lifespan). FYI BF4 ran just fine at "normal" 1440p as well as 3440 x 1440 with a Titan followed by a gtx 980.
I cant give any budget recommendations as I tend to blow a lot of money on 'puter shit (new build is a Rampage V Extreme w/ the 5960x and 32GB of DDR4@3000) but I'm sure any x99 mobo/CPU combo you go with will make you glad you finally retired the 1366.
To OP:
good for you bud......going from one cutting edge setup to another and have fun with that bad ass stuff you picked out;)
To OP:
yeah....i've had this puppy for at least 6 years. been through at least a video card per year. i think i'm just feeling the mobo/cpu itch because it's been so damn long....
I was just feeling the itch too. I quit doing video encoding a while ago so blowing a 1000 bucks on the 5960x was admittedly a waste (all I do now is casual gaming), but it had been SO fucking long since I built a system, I just wanted to.
What does my age have to do with it?....you must be ignorant I'm telling you its smoother/way better with HT off running at 4.2Ghz right now....you need to learn a bit more bud...HT is damn near useless and not needed for BF4 I would need a good bit more Vcore and just further excessive heat already warm enough as it is.... older HT is just not utilized well... obvious blocking with threads/core usage hence the lag/hitching/stuttering/more latency I get, turn it off....
after like 3.8ghz need massive Vcore increases and it will take it/use every damn bit of it too.....and on air its rather difficult at least with this heat-sink just a thermalright truespirit 90m nothing crazy at all...not to mention this board/VRMs....would be a very different story with like the much nicer X58 boards.... better cooler or all water etc...
