Hi guys, long time no browsing
Well I've finally snapped and my Athlon64 3400+ just doesn't cut it anymore. It's fine for most things, but I do a lot of video encoding, especially with x264, so I need all the firepower I can get.
My aim is to build something that will feature dual processors, so one of the pair will be equal to or faster than my Athlon64 3400+ Clawhammer (1MB cache, only S754 though), so that I won't suffer when it comes to non multithreaded apps. I'd also like to ensure it's significantly faster than an Athlon64 4800 x2 (I suppose that's fairly easy).
I'd like to keep the cost $500 or below for each CPU if possible, I was thinking of dual Opteron 250's. Fortunately a lot of the programs I use benefit from multi processors in some way, here's a little list of what I commonly use, the most used being at the top of the list:
x264 CLI (H.264 encoder - www.x264.nl)
Virtualdub/AVISynth & XviD
Adobe Photoshop
Adobe Premiere Pro 1.0/1.5 (cringe, I guess I should try the older version sometime)
Adobe After Effects 6.5
Considering dual CPU is a scary thought at the moment, many questions. I'd appreciate it if you guys could help me out on these. Unfortunately I'm stuck using my mobile phone's GPRS right now, it's slower and less reliable than 56k! (or trust me, I'd have done a lot more googling, that's half the fun
I'd very much appreciate any linkage that might be useful.
1) Cases
I'm tight on floorspace. Currently I'm using an Aopen H700A tower, it's a 6 bay beast but is only as wide as a basic case (about 200mm). It's about 450mm deep but isn't large enough to take a dual CPU board. Can anyone recommend a 6 bay case or equivalent that will house a dual CPU board? I can go up in depth and height, but not width.
2) RAM
I hear that you need registered RAM with some (if not all) boards. It's my understanding that due to it's error checking that it's more stable. Might be a silly question but will I notice this increased stability, or will Windows still crash all over the place?
(ie will a normal user benefit, or only mission critical stuff).
3) Motherboards
This has been my biggest stumbling block so far, maybe due to my requirements. I need a board, preferably that has:
-1x AGP/PCI Express (PCI Express preferably since I plan to get a graphics card with H.264 decoding)
-1x PCI-X (I have a 3ware Escalade 9500s, and I'd like to make the most of it.
-2x PCI (For my DVB Tuner, Soundcard and possibly additional ATA Controller (or could these be plugged into a PCI-X slot also?).
As for onboard features, I don't care what it has or hasn't got. Onboard LAN would be good, I guess that's pretty standard though.
4) Power
Obviously I'll be needing a new PSU. I'll be running 4-6 harddrives, 4 CD/DVD drives, 2x Opterons and probably a Radeon X1000 series, I'm guessing ~550W should be sufficient. I believe my current rig of 2 harddrives, single Athlon 64, 4 CD/DVD drives and a Matrox Parhelia uses about 280W (seems low, does that sound reasonable?). Also is there any specific name for these PSU's?
5) Cooling
Now this is a scary thought. I'd be tempted to grab a couple of those big copper heatsinks that Thermalright produce and stick a Vantec tornado on like I have done with this system (though it seems to be running hot recently, I wonder if something came loose, or if my mobo is lying). Other than that it would have to be watercooling, but I have never attempted watercooling before, so I have no clue of what is involved, let alone costs or reliability. Yes, I bet this is going to be something that gets VERY hot.
6) Overclocking
I don't really need to know this since it's something I can find myself should I go dual CPU, but thought I'd throw it in anyway. Any of you overclocked dual Opteron rigs before, and what sort of result did you get?
Also how do Opterons differ from Athlon 64's? I understand that they are tuned for server like usage, but I thought I heard somewhere that they are good with video processing too.
Well that's about it I think, I appreciate your time if you've read this far
One thing to note is that I live in the UK and we don't have as much selection as you guys, so I would probably end up importing my stuff from www.provantage.com
Adobe Photoshop
1) Cases
2) RAM
3) Motherboards
4) Power
5) Cooling
6) Overclocking
