Considering Custom Water Cooling Case (Need Input!)
I brought a standard Lian Li case (with a window) and did a few mods myself:
http://www.btonkinson.com/PC/computer.htm
I went for the Zalman "Resorator" water cooling solution. Although I have a socket AM2 board you can use the same block it's a "ZM-WB4 Gold". My AMD dual core 64 is running at 2309MHz and is usually at 38 degrees when idle and no more than 45 when really stressing it.
Not sure about your GPU question - never tried water cooling one.
Hope this helps..
Do I need a reservoir or just a fill port?
-its up to you, you can save $30 and use a fillport and T-line or you can make filling/draining easier and use a res.
What type of pump would you recommend?
-a Laing D5 (swiftech MCP655 is the same thing) or a DDC-2 with petras custom top here
Is it possible to attach a GPU block without voiding the warranty?
-you have to check with the MFG but evga is the only one i know of that permits using water cooling without voiding the warrenty. it usualy doesnt hurt anything and if your card all of a sudden dies just put the stock heatsink back on, be careful not to scratch the card, clean it good and ship it back they shouldnt care. if its obvious that the card died from water damage that probably isnt covered by warrenty.
Well I have an evga... so thats nice! What CPU block for a 939? What block for my graphics card?
If I have a T-Line will I need a res too? Or is it one or the other?
