cliffg
- Apr 8, 2009
I'm considering upgrading my wife's desktop computer. For now it's mainly used like a netbook, as you'll see from my responses to "Answer these questions first".
I've been trying to snag one of the nice Fry's mobo / processor combo deals, but I've gone by, called, or tried to "buy online, pick up in store" four times now, and every time the deals are gone (Renton, Washington). I'm beginning to think you have to be there within 10 minutes of the combo being offered.
So I'm re-thinking my "lowest cost" approach, and am thinking about building something that can be handed down to the kid in a couple of years for school work or light gaming or engineering projects or whatever (hopefully not surfing too many porn sites).
He's 10 yo, and will most likely help me put the build together (first time for him, sixth or so for me, although my first SFF).
I'd like this to be a SFF build, mini-ITX, as you can see from my proposed part list. I'd like it to be relatively low power, small, easily moved, and stable. There's a couple of other reasons I'd like it to be m-ITX, but if I'm giving up way too much, I'll re-consider and go micro-ATX.
I've always built Intel-based desktops in the past, but it seems the sweet spot (at the moment) for a lower priced, but still fairly powerful system is AMD. This summer or later I might build out a system for hobby use, which will probably be i3 based, using Gigabyte's soon-to-be-released (maybe) m-ITX board (H55 chipset, USB 3.0, and some other nice features). However, barring a hot combo deal that I can actually get, we're talking $250+ for a decent m-ITX mobo and i3.
So I looked at AMD solutions, and while the Zotac GF8200 mobo doesn't knock me off my feet, it's $30+ cheaper than the H55 mobos. And Athlon II X2 3.0 Ghz processors are $65 at the Egg (so the two together are $100 cheaper than the Intel solution).
Here's what I'm thinking for the basic parts:
AMD Athlon II X2 3.0 ($65)
Zotac GF8200 ($90)
2 GB DDR2 1066 (G.skill or equivalent, $65)
Sugo SG05 ($100)
Slimline DVD ($60)
I already have a 40 GB Intel SSD I'll use for the HD.
I could save a few bucks with a cheaper case, but I think the Silverstone is worth the cost (in particular, the power supply is supposed to be good, and has enough headroom for possible future needs).
The integrated graphics in the Zotac are more than enough for my wife's needs, and if it gets handed down to the kid later, he can always put in a cheap graphics card.
BTW, Atom (or similar) processors would be enough for my wife's needs, but I really hate giving up that much processing power (compared to what I'm planning here), and assuming my son does a bit more now and in the future it's good to have the "headroom".
Answers to the template questions:
Mostly e-mail, word processing, web browsing, pic and music management, some light gaming.
Would like to keep it under $500.
3) Where do you live?
Seattle area.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
As mentioned above - Mobo, CPU, RAM, SFF case and power supply, DVD drive.
Monitor (Dell LCD), speakers, keyboard, mouse, etc.
6) Will you be overclocking?
Not at first, son may in future years (if m-ITX he'll just have to live with limited or no OC'ing capability)
Currently 19", may buy her a 22" in the future. No need for multiple monitors.
Soon. Will order within a few days, unless plans change.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No RAID, firewire, crossfire, SLI, SCSI, serial port, etc needed. (Important data is backed up on a raided NAS on our home network.)
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Yes, Win 7 (bought the 3-pack, so I can install either 32 or 64 bit). I don't see much advantage to going 64 bit, but can if it will help anything. (My desktop with 4GB RAM will soon have Win 7 64 bit installed on it.)
Anything I've missed, or am I way off base here? Am I on track with my "sweet spot" thinking, or is there really that much more bang for the buck with an i3 / H55 solution (or older generation Intel)?
As always, I appreciate the comments and feedback on this forum.
Cliff
Zotac GF8200 ($90)
Sugo SG05 ($100)
Slimline DVD ($60)
Seattle area.
Cliff
