I'm on a 30" display as well and I switched from a GTX295 (similar enough to GTX280 SLI?) to a 5870, and have absolutely no regrets. I found the 5870 to be quieter, use much less power (~40% less, but probably even more for you), and is much faster once your throw overclocking into the mix. I haven't run into a single game I couldn't max out at 2560x1600, even Crysis.
...............You sure you don't have four 5870s....because even four 5870s struggle and dip down in the 20 fps range in crysis at that resolution. I doubt you are running Enthusiast settings, but I would definitely like to see a bench.
I actually like playing the original much more than Warhead, so I'll report on that, but yeah, it runs fine. FPS are generally in the 25-35FPS range, everything Very High with 2x Edge AA. The Crysis series are funny games, as they don't always have a significant response to substantial increases in computing power, and they definitely don't play nicely with dual GPU set-ups. Warhead hated my GTX295 @ 2560x1600 and I can't imagine CF is any better................You sure you don't have four 5870s....because even four 5870s struggle and dip down in the 20 fps range in crysis at that resolution. I doubt you are running Enthusiast settings, but I would definitely like to see a bench.
@vcjmoke hows that physx with a 5970 working out for you, I thought that didnt work
