I have an E6600 on an EVGA 680i board. I bought the board a couple weeks ago and wanted to get it tested before my 30 day return window is up. I've been running water, but I'm waiting for a new radiator and some other parts to arrive, so I have it set up on my desk, mounted to a removable motherboard tray. I'm using the stock Intel cooler, and I have a Zalman VF700 on my 7800GT.
Temps are crap on the C2D with the stock cooler, but I've been spoiled by water. At defaults, it idles at 45C. Anyway, with this chip on water, it was fully stable at 9x380 (3.4) on a 965 board with 1.45v, and saw 3.6, albeit flakey. The RAM (2x512 PDP 6400LL - D9's, I believe) has gone as high as 1066 on the 965 board.
On the 680i, I've been trying a few things to see where it will go, and I am also concerned about many of the problems others are experiencing with boards using this chipset. So far, no anomalies have appeared, but I haven't done much yet either.
Since I knew the limit of the chip, I pulled the multi down to 6x and cranked the FSB up. I decoupled the RAM from the FSB and am running it at 800 to keep that out of the equation. My voltages are as follows:
CPU 1.50 (1.46 drooped)
CPU FSB 1.5
MCP 1.5
SPP 1.5
HT Link 1.25
RAM 2.20
All spread spectrum options disabled. All other CPU features disabled (SpeedStep, C1E, VT, etc.)
The board has topped out at 405 (1620). Am I to assume at this point the board is a dud? Or is it the CPU? One other item of mention is that I'm using an Antec TP-II 480, and it only has a 4-pin 12V+ connector. Could this be holding me up? Been thinking about a new Seasonic or Corsair (Seasonic, lol
Whaddaya guys think? Any suggestions appreciated. BTW, I'm not even considering load testing with Orthos. At this voltage, it's idling in the mid 50's...
EDIT: I just noticed cpu-z is showing the vCore at 1.21V - is cpu-z reading it correctly???
THANKS!!!
Tom
CPU FSB 1.5
MCP 1.5
SPP 1.5
HT Link 1.25
RAM 2.20
THANKS!!!
Tom
