- Apr 15, 2005
AMD will still be on 90nm and intel is 6-12 months ahead of AMD on the 65nm transition? ......You make it sound like there is a set date that all cpu manufacturers have to move to 65nm or the world will come to an end.coldpower27 said:Comparing Conroe die size to Windsor is very legitimiate, as they will be out in the same time frame, as AMD will be still on the 90nm DSL SOI process when Conroe ships, AMD has no one to blame but itself for this. It's not Intel's problem that it is 9-12 months ahead of AMD on the 65nm transistion.
The comparison is legtimate becuase AMD will still be using 90nm technology when Intel is using 65nm such is the problem when your slower then your competitor on process transitions.
AMD designed their A64 core for efficiency so it will naturally have a long market life. They don't need to move to 65nm the exact same day intel does in order to catch-up.
I'm very happy that intel finally got their shit together and is releasing a processor that shows signs of substantial strength in almost every comparison benchmark test run so far, but this new Conroe isn't going to bury AMD outright. It isn't even available yet. Just like AMD 65nm processors aren't available yet. We can't trust data from preliminary testing until a majority of the tests run are by independent reviewers (we all should know better than this!).
I think Conroe will be a great product from intel, and if it happens to be better than AMD's first 65nm offerings, then I might upgrade to one.
This depends greatly on a number of things though:
1. Overall system price (cpu + motherboard + memory, etc).
2. Operating temperature.
3. Operating cost (annually).
4. Overall Efficiency (without overclocking).
5. Gaming performance, gaming performance, gaming performance!
It makes me lol at everyone getting stiff e-winkies because intel may actually release a product that will surpass what they have been trailing in for the last few years..overall processor performance. Too bad it took them yet another die shrink to maybe have accomplished that. I say to all these people: Go rub one out already and then wait until the product is on the shelves before assessing it and popping wood.
