ribs1 said:NO, and No
Xeon is a different socket
Ribs
Overclocking isn't high stress? Normal desktops aren't on full time?spy2520 said:if i had to take a guess at my own question, i'd say that xeons would probably be better in a high stress full time environment, and the core2 would be better for overclocking and normal desktop stuff
baronzemo78 said:I've asked this question as well and am curious. Over at extremesystems they seem to think that the Xeons are better but I haven't seen much more then minor anectodal evidence. I'd like for some [H] people to give their opinions on the matter.
xeons are socket 604 and 771, not 775spy2520 said:is it possible to put a new xeon chip in a socket775 board? or do these only work on server boards? if they do work is there any benefit at all?
wooooow....i didn't even know that Xeons came out for Socket T. That's awesomeGhostDog said:
SuperSubZero said:Overclocking isn't high stress? Normal desktops aren't on full time?
(see why this is so confusing?)
A standard non-OC'd Core 2 Duo can't run 100% load full time?spy2520 said:what i meant was a chip that could run 100% load full time without sweating, compared to a chip that could operate at higher frequencies if the load happened to beless demanding...
SuperSubZero said:A standard non-OC'd Core 2 Duo can't run 100% load full time?
amd0freak said:hey, im new to the forum, but not to computers. i have worked extensively at the architectural level with CPU's, especially 939 and LGA775. The architecture matters just as much as the speed, cache, etc.
The Conroe Xeon is for servers. Its instruction set and architecture is designed for the highest efficiency in operations. Thus it is better than C2D conroe for mathematical processes and EXTREME number crunching without error. However, the Conroe's instruction set is of an entirely different nature, making it better for regular applications, multimedia, as well as games. The difference is not stark; however basically you want the C2D conroe (im guessing most of you aren't using this for a server to calculate stuff for your business). ALSO, since i love overclocking and i bet u do too,
, the conroe xeon's do not overclock as well. Their L3 (THATS RIGHT, L3) cache makes this so. Let me explain this. I dont care what newegg says, or CPU-Z, neither are Intel. L3 cache is closer to the memory (L1-L2-L3-System Drives-System RAM) so this also makes xeon better with calculations. Yet, there is more latency from L3 to the two cores, than L2, so it is a bit worse at gaming and regular app. multitasking. This L3's latency also makes for a bit more instability when overclocking. HOWEVER, they run cooler. so they are less stable OVERCLOCKED (more stable stock) but run cooler and are more power efficient.
my intention is to bust all teh myths and rumors of xeon and c2d with facts.
theelectic said:I would like to see some evidence of how the C2D's instruction set is markedly different from the corresponding Xeon - like E6300 to 3040.
Fee said:The E6300 would be the best one for the work he is going to do right?
Fee said:Yea, thats way to go also. but the E6300 is only $191 at newegg and on some application benchmarks the E6300 was faster then the AMD64 X2 5000 and its $170 more then the E6300. i was thinking the E6300 is a good price for the perfornce.
amd0freak said:run cooler. so they are less stable OVERCLOCKED (more stable stock) but run cooler and are more power efficient.
yeah you can look it up in the intel 64-bit cpu instruction booklet, it explains all sorts of instruction sets for hardware, i dont have a copy but im sure u can find it online...um....i cant remember the name exactly but something like 64-bit cpu instruction set book..theelectic said:You haven't really provided any facts. At least in terms of benchmarks or datasheets or anything that can be backed up with hard data.
I know Intel specs the 3000 series Xeons as having no L2 and 2MB or 4MB of L3, and specs the Core 2 Duos as having 2MB or 4MB of L2 and no L3. See here:
http://indigo.intel.com/compare_cpu/showchart.aspx?mmID=884355&familyID=1&culture=en-US
http://indigo.intel.com/compare_cpu/showchart.aspx?mmID=885515&familyID=5&culture=en-US
EXACTLY thats what i was trying to say, in a nutshell.IntelOwnz said:The only difference is that
Xeons:
L3 Cache
Different instruction set
Support for multiple processors
C2D:
L2 Cache
Single processor only
Almost no price difference, but the instruction set on the Xeons give you a huge advantage in floating point number computations, while the C2D's instruction set is aimed at normal desktop activities, it's not designed to crunch huge number sets
Xeons:
L3 Cache
C2D:
L2 Cache
spy2520 said:so does this mean the xeon may have a slight advantage in a desktop environment? or are the unstable overclocks and L3 latencies really an issue?
metallicafan said:Slightly off topic I know but just out of curiosity, Do the Athlons have a different instruction set than the Opterons?
