BlastRadius
- Nov 12, 2004
Hi all,
First off thanks for looking. Please leave any comments you feel relevant.
Obviously like the rest of the gaming world I am amazed by the performance / price of the new Conroe range of CPUs. So much so that I am ditching a couple of my AMD systems and going after a Conroe setup as my main "gaming" rig.
After much deliberation I will be going after an E6600 and hoping to get a safe and stable 3.2 out of it; may try for more depending on reliability and heat.
First Question:
Any particular E6600 to look out for? Week codes? Any particularly good overclocker?
Second Question:
I have heard that the stock Heatsink is a bit of a duffer; tricky to install and not overly effective for heat dissipation at higher clocks. Which heatsink would you recommend?
Third Question: - Motherboards.
Having never had an Intel motherboard I am confused somewhat by the definitions. Which motherboards should I be looking at? And are there any other chipsets out there yet other than the intel ones? - Preferably I would like an Nvidia chipset (Although NO SLI please, single PCIe will suffice).
Fourth Question: - Memory.
This will be my first foray into DDR2. Any recommendations for manufacturer / speed?
Fifth Question: - PSU
Will I be able to use my on an Intel Mobo connector wise etc..? And will be enough for a single GPU setup with average peripherals?
That all said I have about £1000 to spend on this, I already have DVDs and a nice case. And don't forget I am in the UK so any UK suppliers would be appreciated.
Thanks for your time.
EDIT: Updated to include finalised build.
Buying:
Motherboard:
Asus P5B Deluxe Unless someone convinces me to get the P5W DH Deluxe lol.
CPU
E6600 hoping to get 3.2Ghz on stock cooler
Memory
Geil 2X1GB PC6400
Already have and using:
Case 1of 3? Which one for best cooling?
Thermaltake Tsunami
Lian Li PC-60 Plus
Coolermaster Mystique 631
PSU
GPU
Evga 7900GT KO
Storage
2 X WD Raptor 74GB(16mb Cache)
1 X Seagate Barracuda 320GB(16mb Cache)
Sound
X-Fi Extreme music
And DVDs and all that jazz.
Thank you for contributing, I will forget your names as soon as I start this beast up! jk
First Question:
Second Question:
Buying:
Motherboard:
CPU
Memory
Geil 2X1GB PC6400
Thermaltake Tsunami
Lian Li PC-60 Plus
PSU
GPU
Evga 7900GT KO
Storage
Sound
X-Fi Extreme music
