I have an external USB 80 GB HDD which connects to my pc's USB 2.0 port via a 3 ' standard USB 2.0 cable (A male to B male).
PC Af||Am---cable---Bm||Bf...HDD
Recently I moved the HDD and needed more than 3' to reach the pc. I had a USB Hub which has 1 B female connector and 4 A female connectors. I connected the pc via a 3' cable to the hub's B female connector and another 3' cable to one of the hub's A female connectors. The cable's B male plug connected to the HDD's B female connector and it works fine.
PC Af||Am---cable---Bm||Bf ..hub..Af||Am----cable----Bm||Bf...HDD
If I substitute a B female to A female adapter instead of the hub (the adapter is much cheaper than the hub) the pc tells me it can't recognize the device.
PC Af||Am---cable---Bm||Bf ..adapter..Af||Am----cable----Bm||Bf...HDD
The 4 port usb hub has a power input connector but I didn't need extra power for one port usage.
Can anyone tell me why it won't work?
It looks like all the pins (1 to 4) connect to the right pins in every connector pair.
What is different about the hub's Bf to Af connection?
Thanks
Thanks
