connecting PS3 to wireless router
I have two wireless N routers. One is connected to my modem -
TP-Link Wireless N WR1043ND
The other is a D-Link DIR-615 Wireless N Router. I want to stream 1080p videos with my PS3 and I think this might work. I'm just not sure how to set it up.
I want to connect my PS3 to my DIR-615 using Cat5e ethernet and use the router as a wireless bridge. How do I do this with the DIR-615? Is it even possible?
If you can get a clean signal, it "may" be possible to stream 1080p over wireless with Tversity.
IF your dir-615 is version C1, C2, D2, E3, E4 then you can use http://www.dd-wrt.com to bridge the signal.
DISCLOSURE: You can brick (kill) your router with a bad flash. Be aware of the recovery procedure BEFORE you try flashing it.
I bricked my DIR-615 E1 because I can't find the original firmware, and none of the DD-WRT firmwares will load (router keeps rebooting itself, dd-wrt never loads). I'm pretty sure D1 is flashable now, but E1 is not.
