Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
When connecting multiple monitors do you have to use the ports just from one card, or can you also use the ports on your second card (if you have 2x from crossfire)
In crossfire you can only connect to one card. If you don't crossfire the you can connect to both cards and I'm pretty sure you can still do eyefinity with one.
