Connecting MOSFETS together
Colonel_Panic
I need to do a full service of my loop and I want to reconfigure my MOSFET block connections (or put them back on air altogether). The last time I did this, I used 2 Koolance fittings to make a hard connection -- 1 slot video and 2 slot video -- but as a result of the distance, I had to mix and match the extensions, causing a pretty large restriction. I could live with it, but I always want to optimize.
What's the most effective way to connect the MOSFET blocks that are so close together? Should I just eschew the blocks in favour of stock air cooling? (I have 3 radiator fans above and 1 exhaust fan beside)
