Connecting Front I/O Module to Mobo
jotajota
Hi,
I recently purchased a 3.5" Front I/O Module made by Siverstone. The model number is FP31. I am having trouble connecting the audio/mic ports to my motherboard (which is a Gigabyte GA-8I915P Duo Pro). The header cables on the box of the I/O module are labeled differently than the instruction manual for my motherboard labels the headers on the motherboard.
My motherboard has a 10 pin array for the Front Audio Connector. This is how it is arranged:
10 - FSENSE2 xxxxx 9-LINE2_L
8-No Pin xxxxx 7- FAUOIO_JD
6- FSENSE1 xxxxx 5- Line2_R
4- -ACZ_DET xxxxx 3- MIC2_R
2- GND xxxxx 1- MIC2_L
Note: the x's are just to make it so the words don't blend together, they are not suppose to represent spacing of the connectors on the mobo.
______________________________________________________________________
The cables coming from the I/O panel are as follows:
Mic-In
Mic-Power
Ground (2 ground cables)
L-OUT
R-OUT
L-RET
R-RET
Could you please tell me how the header cables on the module translate to hook up to those pins on my motherboard?
Thanks!
