connect usb 3.0 device to esata
rocketr2
I have a 32gb USB 3 flash drive and an external USB 3 hard drive 1tb that I want to use with my laptop. The laptop doesn't have USB 3.0, but it does have a seats port. Is there any adapter I can use ?
What laptop do you have and does it have a PCMCIA or Cardbus slot?
Do you mean an eSata adapter? As in you want to connect your USB3 drive to the eSata port? No, you cannot do that, you would need enclosures with eSata ports.
I have a adapter that I connect to the PCMCIA or Cardbus slot. Look for those.
