How could i sent signal to my tv in order to play games there.
Isnt the best solution to play games to your tv 31" in highest resolution with 2 7800 gtx's?
I hooked up my computer to my 47" widescreen tv (Samsung rear-projection HDTV) through VIVO to component input on the tv and it didn't turn out how I wanted it. I set the resolution to 1920 x 1080 which is 1080i and it still had a blurry look to it, Battlefield 2 wouldn't even start. If you have an LCD or plasma I would say go for it, through DVI, but you didn't specify what tv you have. They just work better with a fixed pixel display. I moved mine back to my 19" monitor.
its only going to look good if you have an HDTV w/ an HDMI input. its basically a small-type DVI connector that runs from DVI on your PC to the HDMI connector on the TV.
