Connect TV and Internet from 1 Master wire ??
steven1110
I'm trying to hook up my cable tv and cable internet in the same room. There is 1 wire running from the wall so i picked up a coax splitter and ran one side to the cable modem and the other to the cable tv box.
the tv worked good but the internet wouldn't connect. The TV will work off of any wire, whereas the internet will only work off of the wire coming out of the wall. A friend told me to try a high dollar coax cable for the internet but that didn't work either.
Is there a certain piece of hardware that I need to do this? Thx for the suggestions and if you have any other place/forum I could look to find the answer please let me know.
The splitter should work. I use a 4way Radioshack splitter and it works fine. Have a 2way one and that works fine too. Maybe you need to buy a better splitter? Monster Cable makes high quality splitters.
Yeah like Gatticus said the splitter should work. I do the same thing you what to do with a no-name splitter from home depot or radioshack. I have comcast cable.
hmmm...that's really odd then. I also have comcast and the modem just sits there flashing on the received light for ages. I'll try again tonight...maybe I did something wrong and just don't realize it yet.
I have the same setup and I think your problem is that you need a "good" splitter. If I remember correctly, normal TV splitter will go up to 950MHz and cable modem uses higher frequency. That means your second link will work since it goes up to 2Ghz. I believe 1GHz splitter will work since I am using a 1GHz splitter.
ok...I bought a monster cable 1000mhz (1ghz) splitter and didn't have any luck still...2 ghz now or is there maybe a problem somewhere else you think? I think I may call comcast tomorrow and see what they say.
Thanks
It could also be a signal problem. I had a ton of problems using a splitter at my parents house for the same purpose. We had to get the cable company to come out and install a signal amplifier.
from my limited experience (my dad's house and mine), cable company likes cable modem to be its own line while cable tv on its own (charter). BUT, the line has to join somewhere right?
What I did was after the guy came and set up everything, I trace the line to a central splitter before the line goes up the telephone pole. I check that splitter out and got the same one. Hook it up in my room and it worked.
Good luck to you..
