Hello, I'm shopping around to replace an aging NAS system. I like what I've been reading about eSATA (6.0Gb/s) and DAS-type setups. However, I'm unclear about some things.
I would basically like to build a small 8-disk box with hardware or software RAID, and then hook it up to a desktop PC over eSATA. I know that things like this exist - for example, http://www.cwol.com/serial-ata/5-bay-raid-enclosure-quad-t5r5esuf.htm is sort of what I am looking to build.
Is this thing running a full (embedded) OS? I know my way around Linux and embedded OSes, and if it is, I am confident I could build something similar. However, that brings me to the next question - how does eSATA work in this case?
My understanding was that a HBA with eSATA (or SFF-8088) could be installed on the host PC, and from there you can use a port multiplier to attach drives. Management of the drives would be done by the host PC. In the case of the machine I linked to (that would seem to be running its own OS), what happens when you connect to the eSATA port of that machine using an eSATA port on my desktop machine? It's like connecting two PCs together over eSATA, isn't it? What is the result?
Also, hypothetically, if I had an eSATA HBA with dual ports, what would happen if I plugged two of the machines I linked above into the same PC? Could I transfer data between them at full SATA speed (assuming my disks could keep up)?
Thanks for helping clear things up for me.
