Confusing Bios Error Warning
PedroDaGr8
I keep getting a MAIN BIOS IS WIDE RANGE PROTECTION ERROR and I don't know what it means. Pls help I looked on google and can't find out what it means.
thanks
EDIT: Argh, I've gotta remember coffee THEN computer. I have a Gigabyte GA-8GPNXP DUO motherboard, and when I boot up I get an error of "MAIN BIOS IS WIDE RANGE PROTECTION ERROR". This isn't even proper english and it makes no sense to me. If anyone can PLS help me it would be appriciated. I need to have this computer rock stable because it is used in my father's dental office.
I think there is a definition of that in the back of the motherboard manual.
At the very least you should be able to get into the bios or cmos menu (if that board has the dual bios chips) and turn off the "halt on wide range protection" error message
That MB has a dual BIOS, the main one is toast. If you had a normal MB it would be dead now.
http://www.digital-daily.com/motherboard/gigabyte-8iexp/index03.htm
"Wide Range Protection: It allows booting from the backup BIOS if the main one is damaged"
You need to reflash the Main BIOS to a good copy. Just be VERY carefull to not damage your backup bios, because if you do, your MB is toast.
edit: If I were you I would consider calling Gigabyte's support to have them talk you through the procedure. At the very least read your manual's description on how to do this a couple of times to be sure you don't flash the wrong BIOS.
==>Lazn
THanks a bunch everyone, I'll get the new bios and flash it. I'll definately read on how to flash the bios first. THanks again
