D
Deleted member 89137
Guest
Hey, so I finally got a receiver and just set up surround with matching Pioneer Andrew Jones full range speakers for the center, rear and subwoofer, and am using my Yamaha NS-6490 3-way's as the front left and right.
I am a bit confused on how this should be set up with my PC though. I went through configure speakers, set it to 5.1 and full range, and it sounds great. The problem is, after I did that, the receiver only has these options for surround mode:
Stereo
Multi CH Stereo
Multi CH In
Virtual
Direct
_
Before I did configure, I had those options, plus:
PL II Cinema
DTS NEO 6 Cinema
_
I see in the properties for the playback device that the receiver supports:
DTS Audio
Dolby Digital Plus
DTS-HD
Dolby TrueHD
Dolby Digital
_
Shouldn't the receiver's surround mode be DTS? I think the only one that makes sense for watching movies with DTS audio is direct mode? Am I right? I feel like this means my PC is decoding the DTS instead of the receiver? Any help is appreciated, trying to make sure I have everything set up correctly.
Stereo
Multi CH Stereo
Multi CH In
Virtual
Direct
_
PL II Cinema
DTS NEO 6 Cinema
_
DTS Audio
Dolby Digital Plus
DTS-HD
Dolby TrueHD
Dolby Digital
_
