Confused by CPU speed reading Q9450
luigidon
Slightly confused that my CPU is supposidly a Q9450 @2.66Mhz
yet CoreTemp and CPUZ as well as the Mobo system montior is reporting a speed of 2333mhz... actually CPUZ cant make up its mind over the core speed is and occassionally switches between a multiplier of x6 = 2000 mhz and x7 = 2333
not overclocked yet ... just trying to establish a baseline ...
is this normal ?
:confused:
Speedstep, perfectly normal. All it does is lower clock speed when idle to save energy, keep cooler, etc.
If you overclock (heavily at least) it's better to disable in BIOS.
Put it through a load test and it should clock up higher.
cheers buddy ....
Loaded it up with Prime95 (64bit version) and not peaking above multiplier 7 with speed of 2333 ???
My temp are 58, 52, 57, 57 core 0-3
noob on this as you can tell ... appreciate any advice of the speed and temps :)
