Confused between power cords...
Smallsz92
Hey guys I have a quick problem, I have two power supplies cords and one goes to the Corsair TX750 and the other goes to the Corsair HX1000. How do I discern between the two? Thanks! xD
One might be a heavier gauge than the other, but I don't think there would be a huge difference. Usually cords are marked to indicate max amperage, you can extrapolate wattage from there if there is any difference at all.
Well one has a tag on it that says 125V 13A and the other has 10A rather than 13A... I'm guessing take the 13A?
