confused about radiator names
That doesn't help. It doesnt list GTS. I just want to know if they are the same (dangerden messed up the name) or if one is better
Fin density. GTS has more fins and is best with more static pressure to push air/heat through. I also believe the stealth gts rads are smaller in size.
the GTS and the GTS are listed with the same dimensions.
I just need a good radiator that is under 30mm thick
I'm pretty sure that's the same radiator. DangerDen just rearranged the name a little.
GTS = GT Stealth
GTX = GT Extreme
I can see how it could be mistakenly labeled "GTS Stealth". Dangerden is about the only place I can find anything named that.
they are the same thing just someone messed up when the listed it
the GTS is great... my wife had one on her rig and it stayed pretty darn cool
