I'm getting ready to redesign my WC rig and was thinking about using quick connect fittings this time. I was checking the out at:
http://www.mcmaster.com/asp/loadpagerange.asp?begin=148&end=152&qi=
but I'm a bit confused. I'm using 1/2" ID Tygon, but I'm not quite sure which fittings to get. Which ones have you guys had the best luck with? Also, I assume that we would need ones that are barbed on one end for the hose end?
