Confused About My CPU
d uses netburst and it runs hotter.
duo core 2 runs at lower frequancy and does more in a clock.
Carloswill said:
So what is the difference between my "D" and the Core 2 Duo?
Core 2 Duo is faster and more efficient. Uses less power (supposedly) has SSE4, Virualization, and is not NetBurst.
The D's should be 64bit compatible as well. The other main difference, aside from being a totally new design, is that the Pentium D's have L2 cache for each processor...as in 1 MB for each core for a total of 2 MB...or so. The Core2Duo's have one larger L2 cache that's shared by both cores...for example, my 6600 has a 4 MB L2 cache, that either core can use.
