Confused about my 8800 specs.
Exce
Hey fellas. I have an MSI 8800gts 640MB that i bought about a year ago. I was looking for a second one for SLI on ebay since the new GT's are comming out. So i was trying to find one that matched mine in clock speeds, except, well in my Dual Core center, it says i have a core clock of 513mhz and memory speed of 792mhz. Yet all the ones i find online that match my product (see link below) say they have a memory speed of 1700 or so. Did the early 8800GTS's that came out, have really bad memory clock speeds or something? Also if this is the case and mines just really low, what kind of 8800gts would be the best match for mine?
http://shopper.cnet.com/graphics-cards/msi-geforce-8800-gts/4014-8902_9-32335147.html#p5
You don't need to find the exact same clock speeds as enabling sli will default to the lower speeds of the two cards. Although you could just overclock the lower clocked one to match your higher clocked one. As for the memory speed you're seeing for other cards, it's probably just the effective rate they're quoting which is just the double of the base ram frequency.
could you explain this "effective rate" term? I havent heard it in video card terminology before, and while i was searching i found someone else in another forum mention that.
the effective memory is your memory speed x2 so that 792 memory speed of your card runs at an effective rate of 1584, so well still lower than what your finding on ebay, its would OC no problem to match whatever you find on ebay :)
I mena look at the card in my sig 650/1650/2100 is my cards Core Clock/Shader Clocks/Effective memory Clock to reach that effective memory in rivatuner I have to overclock my cards memory to 1050
okay thanks a lot. So, i do not need 8800's of the same speeds in any way, and i do not need them to be the same brand right? any thing else i should know?
Brand doesn't matter, you can pair XFX with BFG or EVGA with PNY (etc, etc), just make sure you have the same memory size. So make sure you don't buy a 320mb card, but a 640mb one.
