Okay, so after deciding on a new monitor to replace my dying CRT (I am going with an HP ZR24w), I figure it is time for an upgrade of my main system.
The current configuration is as follows:
AMD Athlon X2 6000+
2GB Corsair DDR2 800
Gigabyte Mobo (forget the exact model #, standard features)
EVGA GeForce 9800GT 512MB
HT Omega Claro Plus+ Sound Card
80GB Kingston SSDNow M Series (Same as Intel X25-M, OS/installed programs drive)
72GB WD Raptor 10Krpm (old system drive, various use now)
500GB WD 7200rpm (storage)
450W Antec PS
I plan on doing the upgrade in 2 stages (due to financial restrictions): a core upgrade (Mobo, proc, memory), and a video/power upgrade (video card, power supply). These are the components I am considering:
AMD Phenom II X4 955 Black Edition 3.2Ghz
4GB (2x2GB) Corsair XMS3 DDR3 1333
GIGABYTE GA-770TA-UD3 AM3 (Basic, 1 - 16x PCI-E)
EVGA GeForce GTX 465 1GB
Antec NEO ECO 620C 620W
According to the power supply calculator on Antec's website my current power supply will be able to handle the core system upgrade, I will need to upgrade the PS if I get a more powerful modern video card. My primary concern is gaming performace. I currently play most games at my desktop resolution (1280x960 @ 120Hz), I plan on playing games at the native res of my new display (1920x1200 @ 60Hz). The question is: how much of an impact does the dramatic increase in resolution have on the GPU? For example, will I have to turn down the current graphics settings that I use in games in order to account for the increase in resolution? Additionally, if I do end up going with the new video card and power supply, will my current core system present too much of a bottleneck to take full advantage of the available performance increase?
Any input on these issues would be much appreciated! (i.e. - what order you would do it in and why)
AMD Athlon X2 6000+
450W Antec PS
