First overclock here, using a q6600. I've already turned off c1e, speedstep, setting pci-e freq. to 100, etc.
I have it set to 9x333 and the memory is running at 2.0 so 667mhz and 5-5-5-15.
A short prime95 run gave no errors.
Now for the CPU voltage it's set to 'Normal' and I'm guessing I should manually set this for best results, so where do i start? with my vid of 1.25 for voltage?
I'm confused with core voltage, looking at cpu-z the idle core voltage reads 1.200v and when I'm running prime95 it drops to 1.8~, I would think it would increase when stressed
