Other than opening the case, is there a way to confirm that the components you order from a boutique builder are actually the components that were sent?
run command prompt and enter dxdiag, it should list system components. there are other ways too. under control panel look for system properties, that lists system info.
Right click on My Computer -> Properties (tells CPU speed-if not oc'd-results vary, and memory capacity), ->device manager and browse through here to see different listings.
Here's where you'll be looking:
Storage capacity can be found in the My Computer menu.
If your cpu is overclocked, device manager may not be able to detect it's current speed, I use CoreTemp for that. I do have a Q6600, but it's currently at 3.0GHz, not 2.4GHz (the stock clock frequency).
